TwinTurbo.NET: Nissan 300ZX forum - Re: code 35 (EGT)
Subject Re: code 35 (EGT)
Posted by txq45 on March 17, 2011 at 10:18 PM
  This message has been viewed 632 times.
In Reply To code 35 (EGT) posted by gottwnz on March 17, 2011 at 04:33 PM
Message The EcU was returned and checked with Nistune with NO problems then tested in another Z with NO codes thrown.
Before installing his ECU there was no codes, but upon installing the ECU he had a knock sensor code ,, which I told him to check the VTC and knock sensor wires,, at that time he found that the connectors were crossed. After re-installing the ECU the knock code was gone but the CAS code came up,,upon switching out CAS there was no change,, he checked the wires and found that he had one on the wiring harness which was pinched (CAS) corrected that and the CAS code went away..
Next, the code came up for the EGR...upon receiving info on that I sent him the ECU pin out to trouble shoot
Nistune Dealer
Built Automatics -ECU socketing ECU eprom upgrades
WWW.AAA-HiperformanceAuto.com
