You do just need to remove the old pipes but doing so isn't that easy depending on what tools you have. Some of the bolt locations can be a pain to get to. You might have to remove your trans to get to the bolts on the down pipes. The o2 sensors will go back into the new set of pipes so no worries there. Then you can delete the AIV. EGR you shouldn't need to mess with for this job.
