So im needing a little help getting the Z unit up and running again. Last night i had some time after work and decided to relocate the ptu under the nose panel. While in there i also decided to replace all the vacuum lines. Once i finished last night i went to start her up and she cranks but does not fire up. Ive checked and checked to make sure ive plugged in any harnesses that i had unplugged due to the relocation and everything was put back together properly. My PTU subharness has seen better days but all the connectors and pins appear to be fine. I guess my question is, How faulty are these PTU's and subharnesses. Im just trying to diagnose the easiest step first before i go through all the wiring again to make sure i didnt cut and wires... My first instinct points to the PTU though.. Thanks in advance for any input!
