1. Unplug Coolant Temp Connector 2. Unplug ECU Connector 3. Unplug TPS connector 4. Set meter to 10-200 ohms 5. Place Red lead to pin 28 of the ECU connector 6. Place Black lead to pin 30 of the ECU connector You should see an open condition (go to 7)7. Keep Red lead on pin 28 and place the Black lead to a body ground You should see an open condition. Repeat the same for pin 30 8. Test Continuity between pin 30 and TPS (black wire) Continuity = YES Loop Test (Short) 9. Place Red lead to pin 28 of the ECU connector 10. Place Black lead to pin 30 of the ECU connector Place Jumper across Temp sensor connector pins Continuity = YES
