TwinTurbo.NET: Nissan 300ZX forum - Re: I'm trying to figure out my problem with my coolant temp.
Subject Re: I'm trying to figure out my problem with my coolant temp.
Posted by njz on March 13, 2011 at 7:19 PM
  This message has been viewed 274 times.
In Reply To I'm trying to figure out my problem with my coolant temp. posted by Worm Boy on March 13, 2011 at 06:32 PM
Message If you want to check between Sensor and ECU just unplug
the temp sensor, first remove the ECU and using ohmmeter go on pins 28 and 30. once an open condition is found, place a short across Temp sensor connector pins. you should now see a short.
