TwinTurbo.NET: Nissan 300ZX forum - LTG is a 30amp fusable link "Primary Power" which in turn
Subject LTG is a 30amp fusable link "Primary Power" which in turn
Posted by njz on March 13, 2011 at 6:54 PM
  This message has been viewed 395 times.
In Reply To LTG Fuse and smoking PTU Problem posted by scottacc on March 13, 2011 at 04:00 PM
Message branches to other fuses which are located in the Relay box and fuse panel on driver side kick plate. I suggest you remove your ECU because LTG powers it. Make sure your ECU is not toast. You will need to check each wire between the F1 connector (ECU) and each connector they are not shorted or grounded.
