Is it normal for rear wheel bearings to have play after the halfshafts are removed? They felt tight and turned smoothly with the HS attached, but after removing the knuckle assembly for the bushing job, there is a lot of slop and movement by grabbing the hub. Is it possible that torquing the large HS nut is what holds the bearing together? Or are my bearings just completely shot? Thanks
Rear wheel bearing play - hunterg23:33:46 03/12/11
