TwinTurbo.NET: Nissan 300ZX forum - could possibly be connection at ECU
Subject could possibly be connection at ECU
Posted by Burton(PA) on March 12, 2011 at 4:03 PM
  This message has been viewed 291 times.
In Reply To Nissan dealer vs local mechanic problems = sputtering + loss posted by 300zxBoulderCO on March 10, 2011 at 06:27 PM
Message check to make sure the ECU plug is seated flushly. sometimes when you over tighten the bolt on the plug it causes the outsides to curl up and not be seated, you might just need to back out that bolt and re-seat the plug. i've had a similar issue with mine and that's all it was.
good luck.
