TwinTurbo.NET: Nissan 300ZX forum - Re: water leaking under passenger side dash..
CmyZ
on March 12, 2011 at 7:25 AM
posted by GitNMyBelly
on March 11, 2011 at 05:39 PM
To make matters worse its next to the Battery/ amplifier wire.
Sounds like Heater core. Does it smell like antifreeze? If not then check the discharge hose, it might be blocked.
GitNMyBelly
17:39:20 03/11/11
Sounds like the heater core. (n/m)
Optima
17:42:37 03/11/11
Water or coolant? (n/m)
toykoz32
17:46:59 03/11/11
Maybe the drain is clogged. (n/m)
SactoTodd
18:09:12 03/11/11
Is the drain hose blocked up or falling off?
ZXoltan
18:09:49 03/11/11
blows through fine... (n/m)
GitNMyBelly
18:13:24 03/11/11
Run the heater when the carpet is dry and you'll know
ZXoltan
18:34:12 03/11/11
Re: water leaking under passenger side dash.. -
CmyZ
07:25:40 03/12/11
doesnt smell like coolant. fresh water.
GitNMyBelly
10:25:51 03/12/11
Thanx Ill Try that.... But yeah i did disconnect that drain
GitNMyBelly
19:20:30 03/13/11
Drain tube from your PS Ttop
CoHPhasor
19:16:13 03/12/11
The drain hose is not connected in your picture.
Woody75 (Denver)
19:26:57 03/12/11
