TwinTurbo.NET: Nissan 300ZX forum - ??? Everything began working again yesterday?!
Subject ??? Everything began working again yesterday?!
Posted by doug8867 on March 09, 2011 at 7:32 AM
  This message has been viewed 115 times.
In Reply To Little Help Please: No air blowing from AC or Heater. posted by doug8867 on March 07, 2011 at 08:28 AM
Message The only thing I can think of that was any different was that when I tested the Alternator output several days earlier I noticed the negative battery cable seemed a little loose on the terminal. Not real loose, but loose enough that I could rotate it on the terminal if I pushed with some effort on it with my finger. Didn't do anything about it at the time, but yesterday I remembered it, and thought I should probably tighten it so I did. It was looser than I had thought too, because I was able to turn the tightening nut two full turns with a nut driver to get it tight.
Drove the car several hours later and ALL the heat/AC/defrost stuff worked! Time will tell if it was just an odd coincidence, or if perhaps because the cable was loose it was causing a ground issue that was enough to lower the power output to a level that wouldn't run the blower? Dunno, but everything works as of now. I'll post again if I have any other issues.
