TwinTurbo.NET: Nissan 300ZX forum - Well the right way to test these is with an electronics
Subject Well the right way to test these is with an electronics
Posted by jzack on March 08, 2011 at 6:47 PM
  This message has been viewed 218 times.
In Reply To ptu test posted by kgnissan on March 08, 2011 at 04:24 AM
Message breakout board test rig. Set up the test rig with a decent test load (ie., 100 mA bulb or similiar) and then hit the PTU with a firing signal and make sure the test load works correctly.
PTU is just a simple semiconductor switch. Unfortunately unless you are a bit familiar with electronics - not all that easy to figure this out.
One thing you could do is pull a coil pack, attach a spark plug and ground it. Turn on key, rotate the CAS shaft by hand and see if the plug fires. Run this test on all the packs -- will know for sure that way too?....
