TwinTurbo.NET: Nissan 300ZX forum - Little Help Please: No air blowing from AC or Heater.
Subject Little Help Please: No air blowing from AC or Heater.
Posted by doug8867 on March 07, 2011 at 8:28 AM
  This message has been viewed 313 times.
Message Discovered I've got no air coming out of vents this weekend. No heater, no auto climatic control, no AC, no defroster blowing. All the lights on the dash pod work, beep, etc. I ran the heater diagnostics and it said there were no problems.
I would think if the blower had gone out that should show in the diagnostics?
FYI, In searching through the archives here I read a post where somebody else had a similar problem once and it was caused by an alternator problem. So I tested my alternator /battery output with the car running and the headlights on and got readings that went from 12.8 to 14.5 which seemed to be within normal range.
I would appreciate any thoughts anyone might have on what else to check/test in regards to the blower not working on either the AC, defrost, or heater. Thanks.
