TwinTurbo.NET: Nissan 300ZX forum - Stock, unmodified?
Subject Stock, unmodified?
Posted by -Grimm- on March 06, 2011 at 3:53 PM
  This message has been viewed 153 times.
In Reply To Plenum Pull posted by Khronik on March 06, 2011 at 03:32 PM
Message If so, you will most likely need to replace the coolant lines underneath the manifold, unless you delete them (recommended).
You will need the upper/lower plenum gasket and EGR gaskets, balance tube orings, maybe some small vacuum lines depending on the condition of them currently (they may crack).
Just pulled my plenum to replace my injectors yesterday, after the first time its like a habit.
