TwinTurbo.NET: Nissan 300ZX forum - Yeah, don't worry...
Subject Yeah, don't worry...
Posted by Zinn2win on March 04, 2011 at 4:53 PM
  This message has been viewed 275 times.
In Reply To My timing belt just jumped all kinds of teeth ....Help . posted by xteam300tt on March 03, 2011 at 07:44 PM
Message When the cams 'snap' out of position like that, they just settle into a natural position where there is no force on the valves/lifters. So even if the cylinder might interfere, the valves will always close when the cam releases tension... Get me?
The thing you need to watch is that when you initially set them on the belt marks, is cylinder 1 being tdc with the crank sprocket aligned. Then you just turn the cams (by hand if you a man), they will tension the valve springs obviously, and then slide the belt on the correct marks.
Basically, no matter what, you are safe when the sprocket is aligned and cyl 1 is in the right position.
"It seems like a lot of bolts have been omitted... Judging by the
amount of them in the 'random fasteners' bag. I am beginning to
think my Z is being held together by zap straps"
