TwinTurbo.NET: Nissan 300ZX forum - of course :)
Subject of course :)
Posted by KongZTT GT28RS MD on March 03, 2011 at 7:40 PM
  This message has been viewed 602 times.
In Reply To Did you make sure to use the Z32 shaft seals in the posted by Ash's Z on March 03, 2011 at 06:29 PM
Message "Put the main butterfly shaft through the other side to make the orientation the same as your stock passenger side 300zx TB.
Make sure that you use the 300zx throttle body bearing seals on the 60mm.. They incorporate a double lip seal that is designed for engines that see positive manifold pressure.
Start assembling the 60mm throttle body. Place the bearings in as well as the seal plates etc. You may have to use a punch or
socket as a drift to press them in
_________________________________________________________________________
~~~ Sig starts below ~~~
MySpace for those who have em'
AIM:Shawn300zxTT
-1997 Acura 2.2 CL, 5spd. Daily Driver.. great little car!
