TwinTurbo.NET: Nissan 300ZX forum - You can try getting between the line and hose with a pick
CoHPhasor
on March 03, 2011 at 10:25 PM
Fuel pressure regulator install help anyone in mass?
posted by scott1ct
on March 03, 2011 at 07:12 PM
Then hose it down with WD-40, even heat if you can, then twist alot (on the hose where the line is under the surface).
Should be able to break it free.
scott1ct
19:12:03 03/03/11
Re: Fuel pressure regulator install help anyone in mass?
jaidieray
20:50:18 03/03/11
You can try getting between the line and hose with a pick -
CoHPhasor
22:25:54 03/03/11
cut the hoses + 16441ma/d? Courtesy more to ship than cost?
scott1ct
23:19:37 03/03/11
I think you'd need more than 2 inches.
CoHPhasor
23:32:40 03/03/11
You'll need new oem fuel lines
s3trios
09:53:30 03/04/11
