Last night I put my new timing belt on . Everything was already line up ( cams and crank ) from IPP , just put the belt on and lock it down . Everything went good , rolled the engine back and forth check the tensioner ( 4mm ) all good , went to bed . Today I measured it and it was at 3mm so I went to loosen it alittle to get it to 4mm . I guess i didnt have a good bind on it and the tensioner came back , i heard the drivers side intake gear slip quit a few teeth as i was looking at it i saw the pass. side exhaust gear jump 4/5 teeth . My proublem is the crank is 180 degrees from its timing mark and the cams are all over the place in relation to their marks . I dont know what to do to get them ( all these timing marks ) back to the starting point of the timing proceedure without damaging some valves . So mad right now . . . help please
Thanx
My timing belt just jumped all kinds of teeth ....Help . - xteam300tt19:44:13 03/03/11
