| Message |
no, it isn't easy to get to the manifold bolts. As you've been under there, you already know it's tight down there with the DP and turbo in the way. The manifold has a heat shield held on by 3 bolts running along its center. Under that, the manifold has 2 bolts/port, 1 top, 1 bottom. I'd check the TP/DP and DP/turbo connections. if you're lucky, it's just a gasket, or a bolt has loosened. I pulled my motor to get to my manifold. (Thankfully it was fine)
