TwinTurbo.NET: Nissan 300ZX forum - Here's Ash's guide to compression numbers:
Subject Here's Ash's guide to compression numbers:
Posted by Multi_Read (MO) on March 01, 2011 at 2:14 PM
  This message has been viewed 257 times.
In Reply To STOCK compression readings ( i used search found nothing) posted by 300zxttZMan on February 28, 2011 at 10:32 AM
Message Readings should not vary by more than 10% from cylinder to cylinder. The manual says the limit between cylinders is 14psi.
According to Ash, specs are:
NA: 186 psi is 'perfect' with a minimum of 136psi.
TT: 174 psi is 'perfect' with a minimum of 121psi.
