TwinTurbo.NET: Nissan 300ZX forum - Probably true
Subject Probably true
Posted by Fly-Surf on February 28, 2011 at 10:27 AM
  This message has been viewed 127 times.
In Reply To I'd say you've pinched it by over tightening the nut posted by ZILVER-NZ on February 27, 2011 at 06:58 PM
Message :Those two nuts in that location are way to tight - try loosen them a little an ease the urethane to become flush.
:Whatever the case do not paint it with it pinched in like that. The paint will cure with a memory/difficult to rectify.
I was using those nuts to "hold" the fascia lip flush with the fender lip. As I said below, maybe the bracket needs to be moved or I could put a washer/spacer in there so that the fascia is held where I want but not stressed???
