TwinTurbo.NET: Nissan 300ZX forum - Re: Re: Those supposed "missing" supports only hold the inner liner
Subject Re: Re: Those supposed "missing" supports only hold the inner liner
Posted by Fly-Surf on February 28, 2011 at 7:39 AM
  This message has been viewed 181 times.
In Reply To Re: Those supposed "missing" supports only hold the inner liner posted by njz on February 28, 2011 at 07:22 AM
Message :::The supports go between the fender bolts
Fender Blots --- Fascia ------ support bracket ----nuts
::The bracket stops the Fascia from deforming..
I think you are BOTH onto something! I have those brackets in place BUT the GTZR fascia did NOT have "locating" hole pre-drilled in it so I measured from my previous GTZR front fascia and located the bracket.
I am hoping to move the bracket a little and relieve some of the tension in that area.
FYI...I hit a truck retread at highway speed with the old fascia and my painter said the cost of stripping the old paint (and the concern for damage undernreath) suggested a new fascia.
Turns out the old fascia just needs stripping/repainting...integrity is good!
