TwinTurbo.NET: Nissan 300ZX forum - Z1 GT675RS clearance issue . does the turbo need to be
Subject Z1 GT675RS clearance issue . does the turbo need to be
Posted by xteam300tt on February 25, 2011 at 11:59 AM
  This message has been viewed 534 times.
Message clocked alittle to work ? should i grind alittle off the motor mount ? Or do these turbos require the upgraded motor mounts ? I havent installed the pass side yet so im not sure if it has the same issue or not . I can get the top bolt in but the bottom bolt needs about 1/2 an inch .Thanks guys
