TwinTurbo.NET: Nissan 300ZX forum - Re: compression test results, new spark plugs, and tapping
Subject Re: compression test results, new spark plugs, and tapping
Posted by rhombicblue on February 23, 2011 at 3:16 PM
  This message has been viewed 167 times.
In Reply To compression test results, new spark plugs, and tapping posted by Jiro on February 23, 2011 at 12:48 AM
Message I would recommend that you block the throttle body valves fully open to permit ample air flow into the cylinders. If you performed the compression test in the order shown (1,2,3,4,5,6), and you performed a compression test 3 times for each cylinder, you probably discharged your battery somewhat. Charge up your battery and try the compression test again. This time, test 6 first and don't perform multiple tests on each cylinder.
