TwinTurbo.NET: Nissan 300ZX forum - Slave has about 2k miles. Master, unknown
Subject Slave has about 2k miles. Master, unknown
Posted by blackomega on February 21, 2011 at 7:02 PM
  This message has been viewed 119 times.
In Reply To Fluid should be fairly clear - maybe there's an issue posted by jzack on February 21, 2011 at 05:04 PM
Message The black particles must be coming from somewhere though and I am assuming the MC. considering a rebuild kit, although the CMC isn't leaking at all.
To bleed, I had 2 people this past time:
First person depress clutch pedal.
Second person crack bleeder on slave.
Let fluid flow freely until a trickle.
Close slave bleeder.
Release clutch pedal.
Repeat.
Move to engine bay bleed, then repeat.
Is it better to pump the pedal repeatedly during the bleed or just a single pump each time? I know that if you pump repeatedly then you need a full tank of fluid with hose so it only sucks up more fluid each time, not air.
___________________
"If everybody is thinking alike, somebody isn't thinking."
~~ George S. Patton
