TwinTurbo.NET: Nissan 300ZX forum - Fluid should be fairly clear - maybe there's an issue
Subject Fluid should be fairly clear - maybe there's an issue
Posted by jzack on February 21, 2011 at 5:04 PM
  This message has been viewed 126 times.
In Reply To What am I doing wrong? posted by blackomega on February 21, 2011 at 02:07 PM
Message with the MC or slave? How old are they?
FYI - I like to bleed this way. Open up slave and let the fluid just drip out - once a steady stream flows close the valve, hook up a clear hose, then bleed as usual. Watch hose until all bubbles are gone!
Let things sit for a while - hour or so. Open up engine bay bleeding port and do similar with clear hose to monitor bubbles. Let sit for a while and repeat on the engine bay port....need to keep doing until all the bubbles are gone.
PS -- Speed bleeders can make this job go much easier of all alone...
