TwinTurbo.NET: Nissan 300ZX forum - 91 TT 5sp Transmission problems
Subject 91 TT 5sp Transmission problems
Posted by Coyle on February 21, 2011 at 4:40 PM
  This message has been viewed 133 times.
Message Hey Guys, trying to troubleshoot my transmission issue. The car is a 91 TT 5sp. The car does not want to go into first or second gear at all. I can force it into them, it usually will grind a little going into second. Double clutching helps a little bit. Once I get it up to speed it is fine through the rest of the gears. I changed out the slave cylinder, switched out the stock tranny fluid for royal purple stuff, 2:1 ratio of the 75W90 to Synchromax. Neither has made a difference. Is it about time I start looking for a new transmission?
