TwinTurbo.NET: Nissan 300ZX forum - Uneven ride height
Subject Uneven ride height
Posted by MIKEYNISM017 on February 20, 2011 at 11:29 PM
  This message has been viewed 211 times.
Message A few months ago I had an accident involving an island that destroyed one of my Work rims, along with most of the passenger side front suspension. After replacing the components that were damaged (thanks Bernie) I decided to swap out my stock springs with the Eibach springs that had been sitting in my closet. After I swapped those out along with some new suspension bushings, I put on the stock rims and I noticed that the ride height on the passenger rear was higher. In addition to that, the rear passenger side tire seems to be sticking out more, whereas the driver's side has a tucked look. When I got the car aligned they said the front and rear were back into spec. The z drives perfectly straight at low and high speeds, and there are no abnormal noises while driving or going over bumps. I got under it to inspect the rear suspension, and everything looks fine. So what could be causing this problem? Any help would be greatly appreciated.
