| Message |
and then got an OEM because I thought the AutoZone thermostat could have been bad. I did do the stove top procedure to get it to open up and it's working properly. I haven't done a radiator flush, I don't have any debris, leaves, etc. between radiator and AC condensor. Fan clutch is operating properly, and electric fans turn on after awhile of running my A/C. I'll try and do a radiator flush and make sure I have no air in the system and for NJZ, I have tested the ohms on the temp sensor. What I don't underrstand how is it that the sensor is reading correctly and reading 203 degrees? Wouldn't it be reading what ever temperature is in the radiator even if it's not submerged in coolant?
