TwinTurbo.NET: Nissan 300ZX forum - Do the following
Subject Do the following
Posted by njz on February 20, 2011 at 11:54 AM
  This message has been viewed 201 times.
In Reply To Why is my ECU reading coolant temperature at 203 degrees? posted by Worm Boy on February 20, 2011 at 01:50 AM
Message 1. Check Coolant level, make sure there's no air in system
2. Test temp Sensor (ohms to temp) Use FSM)
3. Check Fan Clutch.
4. Check Aux fan operation
5. Check Water pump for leak
6. possible Thermostat failure
7. Clogged Rad.
