| Message |
hello there i need some guidance im about to loose it and give up, i had sent my na z32 motor to this shop to get it rebuild professionally all done at OEP specs, after putting lots of money on it, i got my motor back and after a couple days the motor was dropped in the car, i hooked up the tranny (replaced clutch stage 2, get a one piece driveshaft and got some headers ), bolted the exhaust back up, radiator and did all the electrical and vacuum lines, it was happy moments for me since i havent been able to drive my car for the past 2 months and a half. so i get ready to fire her up but right before i checked the oil level, antifreeze lever, power steering fluid everything is ok, i go to insert the key and crank her over and... nothing but only cranking and this terrible noise. Im getting this very loud high pitch noise coming from the motor when i crank her up, im lost the whining noise seems to be coming from the bottom end, i need some ideas please help me out, the motor only cranks and makes this noise it doesnt start at all ******* NOTE is a whining noise, not a squeaking noise the alternator, ps, ac belts are good not too loose not too tight they arent the problem.
