TwinTurbo.NET: Nissan 300ZX forum - clutch issues
Subject clutch issues
Posted by ryanZ on February 18, 2011 at 11:16 AM
  This message has been viewed 109 times.
Message About 3k miles ago, installed an aftermarket Southbend clutch on a Stage III TT. Immediately after installation, getting into 1st and reverse were very hard and clutch engaged on the floor, so I adjusted it off the floor some, then would slip, so adjusted lower. I found the only spot that it would not slip was if the clutch engaged nearly an inch off the floorboard. Fastforward a few thousand easy miles: begins slipping above 5k RPMs. Now, barely gets moving once pedal is nearly all the way off the floor and slips immediately with hardly any throttle. Suggestions? Thanks in advance.
