TwinTurbo.NET: Nissan 300ZX forum - Re: Re: Re: Re: Re: engine chatter lifters. rod , bearings?
CmyZ
on February 18, 2011 at 8:48 AM
posted by ttzxna
on February 15, 2011 at 05:09 PM
First check if you oil pan is dented like indicated above, and fix it by replacing the oil pan and making sure the pick up tube is not bent. It also sounds like a VTC intake cam gear.
ttzxna
18:58:04 02/14/11
Your search for "dented oil pan" returned 33 hits in 18.734
BoneZ
19:19:48 02/14/11
txq45
07:45:12 02/15/11
ttzxna
11:10:24 02/15/11
txq45
14:20:34 02/15/11
ttzxna
17:09:51 02/15/11
Re: Re: Re: Re: Re: engine chatter lifters. rod , bearings? -
CmyZ
08:48:45 02/18/11
While replacing the pan you'll also get to replace
CoHPhasor
22:21:04 02/15/11
Re: While replacing the pan you'll also get to replace
ttzxna
09:36:17 02/16/11
Re: Re: While replacing the pan you'll also get to replace
ttzxna
09:37:48 02/16/11
Search is your friend :)
zQuikonE
16:30:02 02/16/11
I replaced the intakes during the plenum pull
CoHPhasor
16:39:23 02/16/11
Just changing the pan probably isn't going to clear up that
Brett@AwesomeZ
15:08:55 02/16/11
