TwinTurbo.NET: Nissan 300ZX forum - Re:you will learn... that mob mentality is not the BEST..
Subject Re:you will learn... that mob mentality is not the BEST..
Posted by tognot on February 16, 2011 at 9:45 PM
  This message has been viewed 195 times.
In Reply To Not true. That is a generalization. posted by CoHPhasor on February 16, 2011 at 03:51 AM
Message :place to gain knowledge about all things. This website is leaps and bounds above others I have seen, but a common occurance is to see something be repeated often enough and "viola" it is true!
When Columbus said the earth was round, all learned men KNEW the earth was flat.
Like wise, go back several years here and the common recommended practice was "gut your pre cats you can really feel the power increase".
Later it was documented ( on dyno by Seb?) ungutted precats made MORE power! oops.
I have a misfire... "change your 02 sensors"
my car overheats..." change your water pump"
those posts are irresponsible. ( not saying you did that Co HP)
SO, my point... oh never mind. joe645733 must have fixed his problem by now.
