TwinTurbo.NET: Nissan 300ZX forum - Re: Re: While replacing the pan you'll also get to replace
Subject Re: Re: While replacing the pan you'll also get to replace
Posted by ttzxna on February 16, 2011 at 9:37 AM
  This message has been viewed 129 times.
In Reply To Re: While replacing the pan you'll also get to replace posted by ttzxna on February 16, 2011 at 09:36 AM
Message ::the likely shady pan seals.
Speaking of seals, hope you did all the valve cover gaskets and the coolant deletes while you were in there.
:and yes i did replace those items along with the coolant delete... what is the easiest way to pull the pan in your opinions. the motor is inthe car. do you think it would be easier topull the whole thing back out ? or should i follow the manual per [ http://www.300zx-twinturbo.com/cgi-bin/manual.cgi ] ?
