TwinTurbo.NET: Nissan 300ZX forum - Re: i would be a little encouraged by the even readings
Subject Re: i would be a little encouraged by the even readings
Posted by tognot on February 15, 2011 at 11:01 PM
  This message has been viewed 100 times.
In Reply To Could be as simple as sticking rings? However since all of posted by jzack on February 13, 2011 at 10:37 PM
Message :Also, I would try a different compression gauge. I have several, no two read the same. I was going to mention WOT, but i see you did that.
Of course, a REAL indicator is a leak down test... I might consider renting the leak down testor ( they are expensive) before I pulled the motor. If you still werent happy, you would have some ammo to back to the distributor with.
