TwinTurbo.NET: Nissan 300ZX forum - coil relay jumper
coil relay jumper
trumpetz
on February 14, 2011 at 10:12 PM
my 1990 tt will not run with out a jumper where the coil relay plugs in. checked fuse links all good. put new relays in both coil and eccs still , nothing. checked grounds. car was fine a day before. has anybody had this problem?
coil relay jumper -
trumpetz
22:12:50 02/14/11
what connector /pins are you jumping
njz
06:28:17 02/15/11
Re: what connector /pins are you jumping (n/m)
trumpetz
14:37:46 02/15/11
Re: Re: what connector /pins are you jumping
trumpetz
14:39:07 02/15/11
Re: Re: Re: what connector /pins are you jumping
njz
17:05:43 02/15/11
Re: Re: Re: Re: what connector /pins are you jumping
trumpetz
19:42:05 02/15/11
What your doing is closing the contact without
njz
20:00:17 02/15/11
