TwinTurbo.NET: Nissan 300ZX forum - They are square nuts, spot welded @ the corners to
Subject They are square nuts, spot welded @ the corners to
Posted by Bernie (NoVA) on February 14, 2011 at 12:28 AM
  This message has been viewed 120 times.
In Reply To Major problem with front subframe bushing bracket bolts posted by DracoZ on February 12, 2011 at 01:22 PM
Message the inside of the rail.
They are installed before the section is sealed up as part of the cars assembly.
You could cut a 1" ish hole w. a hole drill. Hold the nut and then get a rubber plug to seal it.
Bernie
