TwinTurbo.NET: Nissan 300ZX forum - ^THIS. LEAVE the rear PCV that's on the exhaust valve cvr
Subject ^THIS. LEAVE the rear PCV that's on the exhaust valve cvr
Posted by CoHPhasor on February 12, 2011 at 6:33 PM
  This message has been viewed 358 times.
In Reply To I wouldn't get all that worked up about that 1 hose posted by jzack on February 12, 2011 at 04:24 PM
I did my PCV hoses while the plenum was off.
LUCKILY I used the Z1 Silicone hose kit because I had the "snip 'em an replace" attitude.
I hosed myself by doing that to the exhaust valve cover. (pun intended)
I assumed I was doing those valve cover's gaskets, but I couldn't get to the bolts and had to leave them.
I quickly realized that without having that cover off I wouldn't have the clearance to put on the new hose.
I had to shorten the rear PCV hose(new) then put on one side and use angled needle 0nose pliers to try and fold/retract the very flexible silicone hose.
Point being, if it were rubber I could have never done it, as it was I *barely* got that one on there.
Leave the rear PCV hose alone unless you know it's leaking, then at that point, pray.
