| My Z hasnt been running to well for a while now. It idles fine and drives fine, but under boost it hits 16lbs but doesnt really seem to go anywhere. I have cleaned the MAS, put in new plugs, checked the timing, and checked the ohms on the injectors. I am getting an all clear code on the ECU as well. I was under the car today replacing the starter (stupid DP made that fun) and ran the car while I was under it. My passenger side turbo area has always had a little smoke coming from it, but I always assumed it was from an oil leak hitting the exhaust (car has been an oil leak nightmare). When I was under it I noticed that there was smoke coming from the junction where the turbo and DP come together. I am assuming this means I have a bad seal, but is the turbo blown and would i still be hitting 16lbs if so? I am trying to figure out if this is the reason the car has no acceleration under boost or if it could still be something else. Any ideas would be welcome thanks.
 ECZA #309 ROFLMMFAO. Can I PLEASE jump this guys ass!? PLEASE?! (n/m) - ni[x]it 17:09:09 03/03/02 looks great !!! now I need to decide on tires .... - Luke@tirerack 13:48:52 07/23/02 www.discounttires.com ;) (n/m) - SeedyRom 13:53:01 07/23/02 bite me !!! (n/m) - Luke@tirerack 14:10:42 07/23/02
