TwinTurbo.NET: Nissan 300ZX forum - Two other options as well....solder the wires directly to
Subject Two other options as well....solder the wires directly to
Posted by jzack on February 12, 2011 at 11:57 AM
  This message has been viewed 185 times.
In Reply To interesting. so i can just cut open the connector posted by JConcepTTZion on February 12, 2011 at 12:19 AM
Message the sensor. Just be sure seal/shrink wrap those connections since the sensor is in a location that's pretty exposure to water, etc. Not like that sensor needs to be removed all that often....
2nd option is similar to above -- remove the body of the connector altogether, crimp/solder new connectors to wire ends and press fit them onto sensor. Again - just need to make sure everything is well sealed against moisture -- Home Depot even carries brush-on (liquid) wire sealer.
