TwinTurbo.NET: Nissan 300ZX forum - They are independent systems (mostly). Heater core is
Subject They are independent systems (mostly). Heater core is
Posted by jzack on February 09, 2011 at 10:46 PM
  This message has been viewed 147 times.
In Reply To A/C & Heat posted by Khronik on February 09, 2011 at 12:55 PM
Message inside the heater air box. Fan blower is down behind the glove box and the A/C condenser coils are inside another box between the blower and the air box (halfway between center console and glove box).
I'd try to figure out the heater issue first. Perhaps the heater core is clogged - could be (gently) flushed out to verify. Also could be the coolant valve that's a 8 inches or so to the right and above the gas pedal -- if it doesn't open, no hot coolant to the heater core. That valve is operated by a motor via the digital climate control system....
