TwinTurbo.NET: Nissan 300ZX forum - Should be able to remove top nut on antenna and on
Subject Should be able to remove top nut on antenna and on
Posted by ttz'in (NorCal) on February 07, 2011 at 11:36 AM
  This message has been viewed 177 times.
In Reply To Antenna Fail posted by blackomega on February 07, 2011 at 10:55 AM
Message up travel remove mast with slight pull motion, then re-install as you would a new mast and see if that helps, or just install new mast. If that doesn't help, time to remove inner plastic interior panel and remove motor.
