TwinTurbo.NET: Nissan 300ZX forum - There are two adjustments, but only one is usually
Subject There are two adjustments, but only one is usually
Posted by ttz'in (NorCal) on February 07, 2011 at 10:43 AM
  This message has been viewed 95 times.
In Reply To e-brake doesnt work anymore :( posted by RonDeezy on February 07, 2011 at 05:34 AM
Message required, Remove center console and adjust 10mm nuts so that you get 6-7 clicks on the lever. If cable is really "stretched" you will have to start at "Y" adjuster above the rear end.
