:You have the IACV on rear driver side of engine and it has 3 connectors. So start with connectors and you'll probably find out "Y". You can possibly be right...we got kindve lost with connectors when it came to the 3 pins ones that are located above cylinder 5 and 6. Right now the car starts up all the time and seems to be at 1k roms on a cold start but the sound of the motor is very quiet and struggles. Also, the belt is screetching more than ever. But what you're saying makes sense and sounds quite possible. Is there a diagram to those plugs? Or can I maybe take some pics and send them to your email to see if I have them correct?
IF you're looking at the plenum In front of the car, on your left side, there is a 3 pin connector with wire colors white, red, and black i believe. On your right side there is also a connector with those colors, but couldn't find what it was supposed to be connected to so we plugged it into one up top. Lemme know if you can do this for me, and i appreciate your help and others!
