TwinTurbo.NET: Nissan 300ZX forum - Fairly easy once the upper plenum is removed....
Subject Fairly easy once the upper plenum is removed....
Posted by jzack on February 04, 2011 at 7:58 PM
  This message has been viewed 155 times.
In Reply To How Hard is it to replace the VTC solenoids? posted by -Grimm- on February 04, 2011 at 05:01 PM
Message this is a typical plenum pull job. Once that's off the intake valve covers just unbolt and get lifted off. Solenoids are held down by 2 bolts, undo them and remove. You will need to apply some RTV (Permantex Ultra Copper or similiar) under the solenoids on the re-install.
For this type of job -- best to pull the exhaust valve covers too and re-apply RTV there. Those covers (unlike the intakes) use RTV to seal - so extra work to clean them up before re-installing. Just run a search on plenum pull or check the FAQs -- all the same info....
