TwinTurbo.NET: Nissan 300ZX forum - Make sure its the turbo squealing, not something else.
Subject Make sure its the turbo squealing, not something else.
Posted by ZiNnYc on February 04, 2011 at 7:37 AM
  This message has been viewed 137 times.
In Reply To 30 degrees out side and passenger turbo squeeling posted by supersh0cker on February 02, 2011 at 08:46 PM
Message Belts squeal with this weather, may need tensioner adjustment.
You may have a massive boost leak and are linking unrelated issues together. A failing turbo should be leaking oil into the exhaust and you would have definitely seen some blue puffs on decel.
If you have the oil line clogged, the CHRA may sound like that...I've never heard of that but just thinking out loud.
Worst case scenario, you don't need to pull your motor to replace a faulty pass side turbo. R&Ring the CHRAs is simple enough when you get it off.
