TwinTurbo.NET: Nissan 300ZX forum - Re: got under the car and found the oil return was leaking from
aliaZ
on February 03, 2011 at 3:19 PM
posted by supersh0cker
on February 03, 2011 at 01:56 PM
:heres my question, would a leak in the return line cause enough pressure to be lost for the shaft to get poor oil supply?
No
30 degrees out side and passenger turbo squeeling
supersh0cker
20:46:59 02/02/11
If it's seized you'll see zero boost. A squeal only when...
Ted (92TT)
21:06:04 02/02/11
thnx, in first gear for a while it would only get 0psi
supersh0cker
21:11:40 02/02/11
IMO, no harm in driving except it may kill the catalyst...
Ted (92TT)
22:06:33 02/02/11
i have z1 downpipes and no cats, so no worries, how hard is
supersh0cker
22:18:52 02/02/11
Passenger side DP is pretty easy to remove...
Ted (92TT)
23:33:38 02/02/11
I wouldn't say even *you doing it was a good idea.
CoHPhasor
03:48:24 02/03/11
Good point. (n/m)
Ted (92TT)
11:14:49 02/03/11
how would i check if im not getting oil to the shaft?
supersh0cker
22:00:51 02/02/11
anyone taken of the PS turbo? i read that i have to take off
supersh0cker
10:32:15 02/03/11
I've done it with the tranny in the car. (n/m)
Woody75 (Denver)
11:50:13 02/03/11
thnx, any tool that would make it easier? (n/m)
supersh0cker
11:57:58 02/03/11
Curved box end wreches came in handy. (n/m)
Woody75 (Denver)
09:34:07 02/04/11
supersh0cker
13:56:44 02/03/11
Re: got under the car and found the oil return was leaking from -
aliaZ
15:19:20 02/03/11
got back from drive, turbo doing the same thing
supersh0cker
15:34:07 02/03/11
have you checked for boost leaks? (n/m)
aliaZ
21:58:09 02/03/11
i have not checked for boost leaks yet i didnt think about
supersh0cker
09:41:17 02/04/11
Make sure its the turbo squealing, not something else.
ZiNnYc
07:37:48 02/04/11
how do i check if the oil lines are clogged? (n/m)
supersh0cker
09:42:10 02/04/11
Are they stock?
ZiNnYc
16:40:25 02/05/11
