TwinTurbo.NET: Nissan 300ZX forum - If it's seized you'll see zero boost. A squeal only when...
Subject If it's seized you'll see zero boost. A squeal only when...
Posted by Ted (92TT) on February 02, 2011 at 9:06 PM
  This message has been viewed 137 times.
In Reply To 30 degrees out side and passenger turbo squeeling posted by supersh0cker on February 02, 2011 at 08:46 PM
Message you boost would indicate it's turning but making contact. If the turbo is going out you'd generally see some oil smoke, though mine only smoked a little. It could smoke from either exhaust depending on whether the turbo is passing oil through the turbine or compressor side or both. If you remove the downpipe you should be able to inspect the wheel for play and oiling.
