TwinTurbo.NET: Nissan 300ZX forum - Re: TT Power Steering HICAS 'de-vane' question.
Subject Re: TT Power Steering HICAS 'de-vane' question.
Posted by aliaZ on February 02, 2011 at 9:11 AM
  This message has been viewed 132 times.
In Reply To TT Power Steering HICAS 'de-vane' question. posted by Snowmansdsm09 on February 01, 2011 at 10:19 PM
:So my question is, since I'm completely removing hicas from the car can I just plug the hole from the Orifaced banjo bolt? (where the piston and spring was)
:Meaning, instead of using the orifaced banjo bolt can I use a normal bolt??
yes. I'd still use a copper washer to seal it
:Then cap the remaining reservoir tube?
yep
:If that part the of ps pump has been de-vaned, I would assume that means there is no pressure being built so to tie it back into the reservoir with the pre-existing ps hose would seem pointless.
correct
