TwinTurbo.NET: Nissan 300ZX forum - Check coolant temp sensor connection for corrosion
Subject Check coolant temp sensor connection for corrosion
Posted by KongZTT GT28RS MD on January 31, 2011 at 5:53 PM
  This message has been viewed 474 times.
In Reply To idle issues posted by BatmanZ on January 31, 2011 at 11:38 AM
Message You can also take the temp sensor out of water pipe (bigger one of the two) and "twist-sand" the sensor that touches the coolant with a high grit sandpaper or scrub pad etc.
Clean your MAF sensor with some cleaner (do not touch the sensor, just use the spray to clean it and make sure it is completely dry before starting) Also, clean the electrical connection.
Also, your 02 sensors may be fouled.. which you can test to see if they are working properly by using the FSM directions.
_________________________________________________________________________
~~~ Sig starts below ~~~
MySpace for those who have em'
AIM:Shawn300zxTT
-1997 Acura 2.2 CL, 5spd. Daily Driver.. great little car!
